13
This discussion topic has been answered Discussion topic: accessing netflix with sky account1
This message was authored by: georgieboy26
cannot access netflix since adding it to my sky package...   was told to use sky id  to.log in to netflix   but theres no way to do this   I dont have sky q   I.m on sky+hd    dont have a sky puck thing     have a smart tv
This message was authored by: SKY1992bf Answer
Re: accessing netflix with sky account1
@Chodley wrote:
You can't login to netflix with your Sky credentials (i.e. password) but you can do a netflix password reset, using your email from your SkyID, as long as your sky account has been set up and linked to netflix.
Didn't know it was possible to add netflix to your account if you were on an HD contract. Wonder if this is a mistake/oversight in the system.
@Chodley  it's definitely NOT possible, op has unfortunately been misinformed
@georgieboy26  You need to upgrade to either sky Q , glass or stream to use a Netflix account via sky, you can't use one via sky plus HD
Avatar for georgieboy26
Level 2 icon
SO I was missinformed by sky agent that I can have netflix with my sky+hd box   ??
@georgieboy26  Unfortunately yes has it's just not possible to access Netflix through sky on a Sky plus hd box has they don't support apps
hi @georgieboy26
Once activated you can use on any device with the app  or via  a PC browser but unfortunetaly you need SKY Q or Glass/Stream to activate it
https://www.sky.com/help/articles/apps-on-sky-q-and-glass-using-netflix
So yes you have been miss-informed if you only have SKY +HD
@georgieboy26 I wasn't aware that you could add the Netflix subscription to your account through Sky when you have a Sky HD+ box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Level 2 icon
thanks  I am now aware    was missinformed by sky agent
@georgieboy26 I would think the Sky agent was confusing the Sky+HD boxes with the Q and stream boxes
Of course. But can you add it to your Sky account? It sounded like the OP had actually already done that
This message was authored by: best+of+the+best
Netflix is linked to your Sky ID/Account so you pay Netflix via Sky so it's not device specific obviously Sky+HD boxes don't have apps but adding the Netflix subscription should allow the OP to watch it on the Smart TV regardless if the Sky box has apps or not.
I have Netflix billed via Sky but I don't always watch it on the Sky Q box as I use the Firetvstick app or my Smart TV app.
As I mentioned before, unfortunately to activate Netflix through SKY customers do need either SKY Q or Glass/Stream.
Once activated it can be used on any device app  but it does need that initial activation - which can't be done through SKY +/HD boxes.
Fair comment @nigea99 obviously you need to pay full wack for Netflix just cause you have a Sky+ HD box seems a bit unfair
Before I changed my billing from Netflix to Sky I was able to login to the Netflix app on the Sky Q box only thing that has changed is that I'm now billed via Sky and paying less
Like I said I don't always use the Netflix app on the Sky Q box but choose to be billed via Sky than directly by Netflix to watch the same content.
But thank you for the correction.
