Discussion topic: YouTube won’t load
This message was authored by Claire601 This message was authored by: Claire601
YouTube won’t load
YouTube won't load through the sky box but will load through internet
This message was authored by lettice This message was authored by: lettice
Re: YouTube won’t load
Try refreshing your apps;
  1. Press Home on your Sky Q remote, then highlight Settings
  2. Press 0,0,1 and Select to access the Installer menu
  3. Select Apps then highlight Refresh all Apps on this box. You'll see a message that says, 'Your apps are being refreshed'.
  4. Press Dismiss to return to normal viewing.
The refresh can take 24 hours to complete.
Sky Community Superuser
Sky Stream (2 pucks), Sky Ultrafast + using Sky SR203 hub. Sky Protect kit tester.
This message was authored by Quoman7 This message was authored by: Quoman7
Hi @Claire601 Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?
