Discussion topic: YouTube on Sky Q "loading" after pausing..
Message posted on 08 Dec 2024 11:41 AM
Re: YouTube on Sky Q "loading" after pausing..
I came here looking for help with the same issue. It is infuriating. It happens every time I pause a Youtube video. The only work around for it is to rewind the Youtube video a few before hitting play again. That prevents the voices going out of sync and the subsequent buffering while the YouTube video reloads that I know is about to happen. There are posts on this forum from a year ago Its a poor show that Sky haven't sorted it by now. I have even went into the secret menu and refreshed all the apps but it made no difference, so it would appear that Sky have made no attempt to fix the issue.
Message posted on 08 Dec 2024 11:43 AM
@Trevor432 wrote:Its the only way to change the dns on the box, if your ISP locks out the primary DNS its the only way.
Needless to say the issue I was having isnt that of this topic it seems, so anyway I'm getting the same loading issues as everyone else now instead.
My solution unplug the skybox turn it off and plug in the Amazon firestick.
As far as I know, you can change just the DNS and leave the rest blank and it still uses dhcp for those.
Message posted on 12 Dec 2024 08:38 PM
The issue I'm having on my side is when I click a video to play it I get an ad that works fine but then just get black loading screen. Anyone else having this issue?
Message posted on 13 Dec 2024 06:11 PM
Gone on today and the problem has disappeared.
anyone else experiencing a fix today?
tried it multiple times and so far so good, I have had it before where it's worked for a day and then reverted back to the fault the following day so I'll be checking back tomorrow.
just wondering if this is fixed across the board.
Message posted on 13 Dec 2024 07:11 PM
I take it back.... the issue is back again 😟
Message posted on 17 Dec 2024 07:07 PM
Is there a fix on this Sky? It's annoying. It makes it unwatchable.
Message posted on 17 Dec 2024 07:10 PM
I think there is one in the works, just needs to get fully tested and released to everyone.
Message posted on 17 Dec 2024 07:11 PM
Thanks Chodley
Message posted on 17 Dec 2024 08:13 PM
Please forgive the cynicism, but is this fix like Trump's ACA / Obamacare replacement? 4+ years ago it was "two weeks away" and he has " concepts of a plan" now. This problem has been ongoing well over a year so, yes, I will only believe it when I see it.
Message posted on 17 Dec 2024 08:35 PM
I'm not sure anything has changed from the initial "solution" in post 2.
It's a Google problem and has been left with them as Sky say they can't replicate the issue.
You will be disappointed if you think it is fixed in the next Q software update, it isn't.
LG B6 OLED 55” | LG UP75 LCD 43” | sky Q | sky Q Mini | sky Mobile | VOXI Mobile | SONOS Beam 2 | Apple TV 4K | EE Full Works FTTC
Message posted on 17 Dec 2024 10:25 PM
Hmm. I am getting ok results. Did get a momentary buffering pause just now after a few minutes pause and restart but it recovered after a few seconds and is fine. What version are you on dude?
Any excuse to watch 3 hours of The Cure's Songs of a Lost World live gig again 😁
Message posted on 17 Dec 2024 10:39 PM
@Chodley wrote:Hmm. I am getting ok results. Did get a momentary buffering pause just now after a few minutes pause and restart but it recovered after a few seconds and is fine. What version are you on dude?
I haven't seen that, will check it out 👍🏻
My Q is on 280 (hence my "no fix in the next release"), YouTube is on a fairly recent build, web_20241211_14_RC00.
I test the YouTube bug daily across HD and UHD content, occasionally it does work as intended when you pause, but it just gives false hope! 🤣
The vast majority of the time, the skip back and sound dropout issue remains present after a video pause. 😤
Message posted on 17 Dec 2024 10:47 PM
Same version then.
I'll do more testing
Message posted on 17 Dec 2024 10:54 PM
If it helps with testing, I get the bug:
- When Q is recording and when it is not
- When my sole mini is also in use and when it is not
- Anytime between 6 AM and Midnight, 7 days a week
I have had the bug on every software version on Q this year and do not get it when using YouTube on any other device, wired or wireless.
I do have Premium so no ads. I have not had any other YouTube issues, just the pause bug.
Message posted on 17 Dec 2024 11:16 PM
I've had the same on prior versions
not on Premium
just tried a couple more pauses. No ill effects
but will try more
