168
Discussion topic: YouTube on Sky Q "loading" after pausing..
This message was authored by Yamidox1 This message was authored by: Yamidox1
Re: YouTube on Sky Q "loading" after pausing..
Yeah mine hasn't been fixed either, just seems jankier now tbh.
This message was authored by justinp76 This message was authored by: justinp76
I agree!!!! Come on Sky, this is poor!
This message was authored by Jamie190 This message was authored by: Jamie190
This is still happening 5 months later 😟 it's so annoying!
This message was authored by Anna137 This message was authored by: Anna137
If you rewind back 'one click' it seems to make it work better without the sound and rewind issues. Let me know if that helps.
This message was authored by jblink This message was authored by: jblink
So now on Q270.000.10.09L and the Netflix 4K pixelation thing appears to have been sorted although time will tell.  However first time pausing YouTube and........
........same old problem.  Well over a year now and no fix in sight it would appear
Jaxx25
This message was authored by Jaxx25 This message was authored by: Jaxx25
Yeah like I mentioned that in the OP.
While it isn't a fix, it seems to be the least annoying way around it..
It's become such a habit now that I even do that on other players too sometimes.. 🤦🏻
This message was authored by Trevor432 This message was authored by: Trevor432
I have been premium for best part of the last two years and its been ok mostly, just switched back and it seems to be it cant load the ads in and gets stuck. I think DNS could maybe be the issue here, I dont use any ad blockers or firewalls.
I'm not sure because I've been premium for the entire time I've had these issues so no ads on my end and I'm still getting the sound out of sync then skip then buffer
This message was authored by TartanTea This message was authored by: TartanTea
I've been premium the entire time too, I don't think it's connected
So mine is a total freeze every 5 minutes or so, I just went into manual network settings set a the ip to 122 so it wont get a dupe being static and changed the dns from 8.8.8.8 to 8.8.4.4 and everything is running smoothly so far and I got to watch an... ad... yay...!
Still working solidly, if you try update the network settings in manual only change the last number of the Ip address and the dns, anything from 120 to 150 for the IP should be free to use.
This message was authored by Chodley This message was authored by: Chodley
Why did you need to set a static IP?
Its the only way to change the dns on the box, if your ISP locks out the primary DNS its the only way.
Needless to say the issue I was having isnt that of this topic it seems, so anyway I'm getting the same loading issues as everyone else now instead.
My solution unplug the skybox turn it off and plug in the Amazon firestick.
This message was authored by Daisychainette This message was authored by: Daisychainette
I have had this youtube pause issue for months now. It is infuriating. If I pause the video, a few seconds after unpausing the sound will mute for a second then a few moments later the video will either rewind back, buffer, freeze or go to an ad. If I watch an ad, then pause then unpause, it then goes to yet another ad then fails again by jumping back a few mins.  Ads seem to be an issue for sure along with pausing.
This message was authored by Redlodge52 This message was authored by: Redlodge52
I have the same issue. I thought it was due to WiFi so I connected my box directly to the router via ethernet. But it is exactly the same.
Are Sky actually looking at this? We pay a premium and personally I love Sky Q but this issue is starting to frustrate more and more!
