Discussion topic: YouTube on Sky Q "loading" after pausing..
Message posted on 20 Nov 2024 07:18 PM
							Re: YouTube on Sky Q "loading" after pausing..
Yeah mine hasn't been fixed either, just seems jankier now tbh.
Message posted on 20 Nov 2024 07:35 PM
I agree!!!! Come on Sky, this is poor!
Message posted on 22 Nov 2024 10:25 PM
This is still happening 5 months later 😟 it's so annoying!
Message posted on 23 Nov 2024 08:48 AM
If you rewind back 'one click' it seems to make it work better without the sound and rewind issues. Let me know if that helps.
Message posted on 23 Nov 2024 12:52 PM
So now on Q270.000.10.09L and the Netflix 4K pixelation thing appears to have been sorted although time will tell. However first time pausing YouTube and........
........same old problem. Well over a year now and no fix in sight it would appear
Message posted on 23 Nov 2024 06:43 PM
Yeah like I mentioned that in the OP.
While it isn't a fix, it seems to be the least annoying way around it..
It's become such a habit now that I even do that on other players too sometimes.. 🤦🏻
Message posted on 25 Nov 2024 12:10 AM
I have been premium for best part of the last two years and its been ok mostly, just switched back and it seems to be it cant load the ads in and gets stuck. I think DNS could maybe be the issue here, I dont use any ad blockers or firewalls.
Message posted on 25 Nov 2024 12:17 AM
I'm not sure because I've been premium for the entire time I've had these issues so no ads on my end and I'm still getting the sound out of sync then skip then buffer
Message posted on 25 Nov 2024 12:30 AM
I've been premium the entire time too, I don't think it's connected
Message posted on 25 Nov 2024 12:38 AM
So mine is a total freeze every 5 minutes or so, I just went into manual network settings set a the ip to 122 so it wont get a dupe being static and changed the dns from 8.8.8.8 to 8.8.4.4 and everything is running smoothly so far and I got to watch an... ad... yay...!
Message posted on 25 Nov 2024 01:37 AM
Still working solidly, if you try update the network settings in manual only change the last number of the Ip address and the dns, anything from 120 to 150 for the IP should be free to use.
Message posted on 26 Nov 2024 06:56 AM
Why did you need to set a static IP?
Message posted on 26 Nov 2024 07:42 PM
Its the only way to change the dns on the box, if your ISP locks out the primary DNS its the only way.
Needless to say the issue I was having isnt that of this topic it seems, so anyway I'm getting the same loading issues as everyone else now instead.
My solution unplug the skybox turn it off and plug in the Amazon firestick.
Message posted on 02 Dec 2024 11:21 AM
I have had this youtube pause issue for months now. It is infuriating. If I pause the video, a few seconds after unpausing the sound will mute for a second then a few moments later the video will either rewind back, buffer, freeze or go to an ad. If I watch an ad, then pause then unpause, it then goes to yet another ad then fails again by jumping back a few mins. Ads seem to be an issue for sure along with pausing.
Message posted on 05 Dec 2024 02:18 PM
I have the same issue. I thought it was due to WiFi so I connected my box directly to the router via ethernet. But it is exactly the same.
Are Sky actually looking at this? We pay a premium and personally I love Sky Q but this issue is starting to frustrate more and more!
