Discussion topic: Won’t turn on so I need to reboot
This message was authored by: Wareham
It's now happened 3 times in last few days. I turn on tv and try putting sky box on and it says "no signal " so I turn box off and on again and it works.
Re: Won’t turn on so I need to reboot
@Wareham
”No signal” tends to be a message from your TV (in which case check the cables going to the TV). A “no satellite signal” message relates to your Sky box.
Avatar for Wareham
Thanks @Daniel0210 but I'm getting same message on both tv's and it works again when I turn it off then on again. Box is a few years old
Both TVs with different boxes attached fo them? If so, that makes it less likely to be a faulty box imho.
Are they definitely on the right HDMI input first time?
Avatar for Wareham
It's one box serving both tv's. I've just rebooted and it's ok again for now but it's getting more frequent
