Discussion topic: Won’t connect on tv. Tried turning off tv & sky doesn’t work tv still says no network connection
Message posted on 07 Jul 2023 06:30 PM
HELP
tv says no network connection
can't access apps on menu
can change xhannels
watch recordings
all light are on the hub including internet
Message posted on 07 Jul 2023 06:34 PM
Re: Won’t connect on tv. Tried turning off tv & sky doesn’t work tv still says no network connec
@Yosamitysam wrote:
HELP
can change xhannels
watch recordings
Hi @Yosamitysam
Assume this is your main Q box and not a mini.
Try a Network Reset found in Q box Home - Settings - Setup - Network.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Message posted on 07 Jul 2023 06:41 PM
Hiya
thanks for reply, tried doing all that yesterday still not working
Message posted on 07 Jul 2023 06:44 PM
@Yosamitysam wrote:
Hiya
Suggest you try it again @Yosamitysam .
Rebooot the router first.
Who is your Broadband supplier?
Message posted on 07 Jul 2023 08:14 PM
Everything is through sky
Message posted on 07 Jul 2023 08:26 PM
hi @Yosamitysam
Did the main Q box find the Sky router WPS?
Message posted on 07 Jul 2023 09:06 PM
No it just won't find it 😩😢
Message posted on 07 Jul 2023 09:10 PM
@Yosamitysam Are the wifi bands split? The hub has a 2.4ghz & 5Ghz band and the box may will not see them when they are combines.
Message posted on 07 Jul 2023 09:21 PM
Hi @Yosamitysam
Are you sure that you are pressing the WPS button on the Sky router and not the Reset button?
Following the Network reset you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
You must press the router WPS button within 2 minutes of carrying out the Network reset.
Message posted on 12 Sep 2023 06:53 PM
I've turned off everything and removed plugs from the mains and left it alone for 4 hours, I then turned everything back on very slowly and guess what - no change still can't get a network connection
