4
This discussion topic has been answered Discussion topic: Won’t accept me PIN from new card
This message was authored by: Westernman27
Just moved to Sky Q and it will not accept original skyStream
PIN or new card PIN
Re: Won’t accept me PIN from new card
@Westernman27 wrote:
Why don't Sky run 24 hour telephone tech support?
Because that's really expensive to staff and so would require much higher subscriptions?
PIN or new card PIN
What pin are you trying to use @Westernman27
If it is a new card pin would normally be the last 4 digits of the viewing card number.
Failing that you can reset your pin.
https://www.sky.com/help/articles/your-pin-sky-q
Avatar for Westernman27
Tried all options but screen keeps repeating "somethings not working right now" try again later. Looks like a call tomorrow. Why don't Sky run 24 hour telephone tech support?
Hi @Westernman27
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
Answered - Go to Answer
