20 Dec 2024 07:04 PM
Just moved to Sky Q and it will not accept original skyStream
PIN or new card PIN
20 Dec 2024 07:49 PM - last edited: 20 Dec 2024 07:49 PM
@Westernman27 wrote:
Why don't Sky run 24 hour telephone tech support?
Because that's really expensive to staff and so would require much higher subscriptions?
20 Dec 2024 07:10 PM
PIN or new card PIN
What pin are you trying to use @Westernman27
If it is a new card pin would normally be the last 4 digits of the viewing card number.
Failing that you can reset your pin.
https://www.sky.com/help/articles/your-pin-sky-q
20 Dec 2024 07:28 PM
Tried all options but screen keeps repeating "somethings not working right now" try again later. Looks like a call tomorrow. Why don't Sky run 24 hour telephone tech support?
20 Dec 2024 07:36 PM
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
