Discussion topic: Wired and Wi-Fi the router.
Message posted on 03 Jul 2023 08:42 PM
I need to connect the main box via Ethernet. I have 3 minis. One is also connected to the router, the other two wireless hopefully. I appreciate you can only use two boxes at the same time
How do I configure the main wired one in the menus etc
Message posted on 03 Jul 2023 08:47 PM
Re: Wired and Wi-Fi the router.
Hi @Paulta+139
Carry out a Network reset on the Ethernet mini.
Network Reset found in mini box Home - Settings - Setup - Network.
With the Ethernet connected Highlight Status and then select Reset on the right hand side.
Do not carry out any WPS and just wait for the mini box to connect
