5
This discussion topic has been answered Discussion topic: Will sky Q mini box continue to work as extender/booster with 3rd party ISP
This message was authored by: Neilwr
I have Sky Q and two mini boxes. I currently have sky internet but am changing to new ISP. Will the tv boxes continue to work as WiFi boosters for the new ISP?
This message was authored by: Laing1 Answer
Re: Will sky Q mini box continue to work as extender/booster with 3rd party ISP
@Neilwr yes but you will have to turn the feature on under settings and it will only boost the 2.4Ghz as thats what your main box will connect to with a third party broadband
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Neilwr
Thanks. Will having them wired improve the signal? They are wired but the connection/connector at the back isn't 'lit' which makes me think the engineer didn't switch it on - I presume they can be wired and work as boosters?
the router (old and new) is in a different room from the main sky box. The new router only has one output so I think I need a switch to connect it up, assuming wiring will improve the performance.
@Neilwr there are no lights on the ethernet ports on the Q boxes
I think the option may be in the engineers menu on the main Q box so if you cannot find it in the normal settings try in the engineers menu
To enter the engineers menu do the following
press the home button then scroll down to settings and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
don't know if they can use ethernet backhaul as a wifi hotspot. Suspect not (partly because I had to disable wifi on mine) but you never know.
A single LAN port router is very unusual too. Maybe it's an ONT and needs a router, what ISP is that?
Avatar for Neilwr
It's Brillband, using an Amazon Eero 6 router. The router has two ports - but one is for the input so only one spare to connect a Sky box/mini too.
