Discussion topic: Will freesat work with my sky q dish?
This message was authored by: Climo
Hello,
Due to big increases in sky costs I am considering  a move to freesat. I've seen some posts about certain Sky Q dishes not working with freesat. Can anyone confirm whether I will have problems with my sky q dish? Image attached as I've no idea how to identify which one I have. Many thanks
Avatar for Climo
Re: Will freesat work with my sky q dish?
@Climo wrote:
Hello,
Hi @Climo
Provided you get one one of the latest Freesat UHD boxes it will work with the Q Wideband LNB on your Q dish
This message was authored by: samcp88
I've just unplugged my Q box and plugged in my new Freesat 4K recorder and can't get any signal? All the info I read before buying the box said it would work if Q works?
hi @samcp88
I think a few people have found it slightly problematical getting the 4K freesat boxes to work & needs a bit of a 'trick'
I haven;t re-read the instructions to follow them in detail but see this link:
https://helpforum.sky.com/t5/Sky-Q/No-signal-with-brand-new-Freesat-4k-box/m-p/4263605#M570372
Thanks.
I managed to get hold of the local aerial installer and he told me about the box needing to update. Best to leave it on overnight and should all be good to go in the morning.
This message was authored by: TimCollett
Did it update overnight ?
This message was authored by: n1ckarla
Come OP, you asked for help. Give something back. Did it work?
Resurrecting a 2023/4 post probably isn't the best way...
Are you trying to do similiar?  (Q LNBs do work with Freesat 4K receivers)
Well it was the top search on google so it's what I read through only to find an unsatisfactory conclusion.
A year is plenty of time for the op to have worked it out and be able to post back findings.
Exactly, which probably means they won't...  best to start your own thread with your own question etc.
If they don't then they don't and that will be that. The post will drift back down unless someone keeps posting of course. Best just let it go rather than continuing resurfacing it.
Avatar for Climo
Yeah you may aswell start a new thread
The fact that they stopped posting on a Sky forum would suggest that it did work and they have since switched to using Freesat.
