Discussion topic: WiFi good but Sky Q box says no internet
Message posted on 18 Jan 2025 06:02 PM
Message posted on 18 Jan 2025 06:27 PM
Re: WiFi good but Sky Q box says no internet
@Chrismac64 wrote:
My WiFi is connected with 3 green lights but my Sky Q box settings says no internet connection and the automatic IP settings does not display 192.168.0.1 instead it shows 0.0.0.0
Hi @Chrismac64
