Discussion topic: WiFi connection with my sky q
Message posted on 16 Aug 2024 12:04 PM
When i connect to my wifi it connects for 10 minutes then drops connecting and there is nothing wrong with our wifi as works on everything else
Message posted on 16 Aug 2024 12:08 PM
Re: WiFi connection with my sky q
Hi @Julie501
