Discussion topic: WiFi and sky q box keeps losing signal
This message was authored by: Ru7
Keep losing wifi signal. Sky Q box loses signal for the last few weeks. Doing my head in with the constant restarting etc.
Re: WiFi and sky q box keeps losing signal
hi @Ru7
Try completely resetting the connection.
