Discussion topic: Wi-Fi in garden room
This message was authored by: Babs100
Anybody know the best way to get Sky Wi-fi to extend to a garden room at the bottom of the garden. Currently the Wi-Fi only reaches to the back patio.
I thought about running an Ethernet cable from the main Sky Q box to a multi room box in the garden room, but I guess this wouldn't actually create any Wi-fi down there, just give me the sky channels on the box?
Has anybody used any sort of Wi-fi extender that's compatible with sky equipment?
This message was authored by: icesteelman
Re: Wi-Fi in garden room
Hi @Babs100
Home plugs may be a solution using the mains wiring as a network (I assume you have power in the garden room as you mention placing a booster there). One plugged in near your router and one in the garden room. The home plug in the garden room could be ethernet and/or a wifi hotspot depending on the hardware used.
