Discussion topic: Why’s my sky so **bleep** for the amount I’m paying
Message posted on 07 Nov 2025 08:29 PM
Why’s my sky so **bleep** for the amount I’m paying, WiFi signal goes moving out the living room and now the on demand just freezes. This is not acceptable for the amount of money paid each month for a service you provide.
Message posted on 07 Nov 2025 08:48 PM
Re: Why’s my sky so **bleep** for the amount I’m paying
Hi @Andy442
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home.
Regarding your issue
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
