Discussion topic: Why can’t my mini sky Q boxes connect but my main q box does?
Message posted on 29 Apr 2023 07:44 PM
My main Sky Q box is working but the mini boxes and sky iPad app are not connecting?
many tips. Have tried all the usual instructions on screen help.
Message posted on 29 Apr 2023 08:02 PM
Re: Why can’t my mini sky Q boxes connect but my main q box does?
Hi @Sue256
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box
Message posted on 29 Apr 2023 08:03 PM - last edited: 29 Apr 2023 08:04 PM
Edited to remove as I more or less repeated what @oldfella posted
