Discussion topic: Why can’t I have sky without a dish new house
Message posted on 22 Mar 2023 09:20 PM
Engineer came to my house to install sky but went away without doing it re no wires on the outside of new house ???
Message posted on 23 Mar 2023 05:18 AM
Re: Why can’t I have sky without a dish new house
Is that a stipulation from the house builders? Some don't allow dishes on new builds.
Message posted on 23 Mar 2023 07:48 AM - last edited: 23 Mar 2023 07:50 AM
The main reason you couldn't have Sky without a dish is that the signal with all the telly pictures in it was being sent from a satellite and you needed something to catch that signal.
But now you can have Sky without a dish and it just uses your internet connection. It's called Sky Stream. It's a bit different from Q though.
Message posted on 23 Mar 2023 07:48 AM - last edited: 23 Mar 2023 07:52 AM
Sky installers won't carry out a concealed wiring installation from scratch. They also won't enter loft space where developers typically leave cable ends for a built-in cabling solution.
As @Chodley indicates, to get a dishless Sky solution you'd need to cancel the Q order and go for Glass or Stream: be aware that these do not have the same functionality as Q, so do your research.
