Discussion topic: Which setting to return to after watching a dvd
This message was authored by: Silverback2
I have a built in DVD player TV system, after watching a dvd what setting do I return back to for sky Q TV I wasn't made aware of this on my old sky + hd box it was HDMI 2
This message was authored by: ThePope27
Re: Which setting to return to after watching a dvd
Hi @Silverback2,
We wouldn't be able to tell you which port it's in, if you cycle through them one by one when you q box is on and then take a note of which HDMI Input it is,
________________________________________________________________________________________
Sky Q 2TB v2 Box + 2 Mini Boxes - Brsk BetterNet1000 FTTP, WatchGuard M400 Firewall, Plume Mesh
Sky Signature + Ultimate TV Pack, Sky Sports, Sky Cinema, Sky Kids, TNT Sports, MUTV, LFCTV, Racing TV, Premier Sports, DAZN
Hi @Silverback2 Place your TV and SKYQ box on standby, then turn the SKYQ box on, this should turn on the TV, look at the screen as the TV turns on it should say which HDMI port the SKYQ box is connected to just as the picture comes on?
Try hitting the sky button (yes, it's a button) on the remote - it should send a signal to force the input to sky.
Yes, should work, if the TV CEC  hdmi has been setup correctly and the option is set to ON in the Sky Q settings.
