Discussion topic: Which cables do I need to return with my sky q box?
This message was authored by: Zeynep24
I have already packed the HDMI and power cables but what about these in the photo?
Re: Which cables do I need to return with my sky q box?
@Zeynep24
I wouldn't have thought you would need to send those off.
But make sure you add a note inside with your account number and a list of equipment you’ve included, and also make sure you get and keep proof of posting when sending this off.
This message was authored by: DisplayName2000
HDMI that goes from the box to the tv and the blue power cable.
This message was authored by: SlenderRobert
That's just a satellite connection cable & an Ethernet cable, neither of which need to be returned. You can keep or dispose of them yourself.
This message was authored by: bob1234
@Zeynep24They are yours but if you are changing to Glass or Stream you may well need the Ethernet cable. Ethernet is always better than WiFi if it is convenient to use.
Keep or recycle 😉
