Discussion topic: Which Sky Q box do I have? Serial number doesn't make sense.
Message posted on 08 Apr 2024 12:27 PM
My Sky Q box has the hardware version 32B214 after I just updated its system software.
The music section says it is a 1TB.
A lot of comments on this forum state that is should be a UHD box, however, it does not let me download UHD Sky movies, and prompts me to upgrade.
So which is it? I currently use one multiroom Sky Mini, and want to know if I can purchase another.
Thanks in advance.
Message posted on 08 Apr 2024 12:38 PM - last edited: 08 Apr 2024 12:38 PM
Re: Which Sky Q box do I have? Serial number doesn't make sense.
@adingle
You can have a maximum of 4 mini boxes loaned to you by Sky. You can watch Sky content on two minis and the main box at the same time. You may be able to use a 3rd mini box at the same time if you’re using it for one of the apps such as Netflix.
Be aware the original 1TB (non-UHD) Sky Q box only allows one mini to be in use. To check if you have the non UHD 1TB box check in:-
If it shows as 32Cxxx then you have a non UHD 1TB that only supports 1 active mini box.
All 2TBs and the UHD/HDR 1TB permit two mini boxes. Each mini box which is loaned to you may be subject to a one off upfront charge but you only need one Sky Q monthly Multiscreen subscription.
https://www.sky.com/help/articles/sky-software-updates
Message posted on 08 Apr 2024 12:49 PM
Well I have seemingly have a non UHD 1tb but its code says otherwise.
Message posted on 08 Apr 2024 12:56 PM
@adingle wrote:My Sky Q box has the hardware version 32B214 after I just updated its system software.
Thanks in advance.
Are you paying for the UHD pack as part of your subscription? Is the box set to output 2160P on the video output settings?
Message posted on 08 Apr 2024 01:27 PM - last edited: 08 Apr 2024 01:32 PM
Thanks in advance.
Hi @adingle
the hardware versions are very reliable
The 32B2nn can be 2TB or 1TB - the standard issue is the 1TB version
I am fairly certain that you would not even see a UHD version to download if you have a non UHD box & would likely get a different error rather a prompt to upgrade which) as hinted at by @Padam_Padam, i smore like due to your subscription probably not including the UHD add on
As per @Daniel0210 notes the 1TB UHD box (which I am confident you have) does allow 2 active minis
Message posted on 08 Apr 2024 01:55 PM
So I just checked 'My Sky' and my package, which I altered a few years ago, and is also when I got the box includes:
Sky Signature, Sky HD and Sky Cinema.
Why would they have sent me a Sky Q 1TB UHD if my package didn't include UHD?
It's also an all black box, if that helps to identify it, it doesn't have any silver on it.
Message posted on 08 Apr 2024 02:20 PM - last edited: 08 Apr 2024 02:21 PM
hi @adingle
SKY 1TB non UHD boxes have not been made for a while although some are reused - especially for customers changing from SKY HD
SKY 1TB UHD boxes have been the default box irrespective of subscriptions for some time now & many cistiomers do not take out the UHD sub
Message posted on 08 Apr 2024 02:22 PM
@adingle wrote:So I just checked 'My Sky' and my package, which I altered a few years ago, and is also when I got the box includes:
If you're not paying for the UHD add-on then you won't be able to watch UHD content from Sky Cinema I'm afraid. The 1Tb UHD box is the standard box supplied whether you pay for UHD or not.
