Discussion topic: When changing channels screen goes blank and is slow to picture and recordings have software issues
This message was authored by: Gary1114
When changing channels the screen goes blank and takes a while to respond seems to be running slow,also recordings are showing a software issue and part recording and pausing whilst watching.
Re: When changing channels screen goes blank and is slow to picture and recordings have software is
Hi @Gary1114
