Discussion topic: When I watch recordings on my sky q they regularly freeze and you are unable to forward or rewind
Message posted on 05 Sep 2024 02:46 PM
When watching recordings on my sky q box it regularly freezes and you are unable to forward and rewind. All my recordings say part recorded software issue and have gaps in the recording
Message posted on 05 Sep 2024 02:54 PM
Re: When I watch recordings on my sky q they regularly freeze and you are unable to forward or rewin
Hi @Paulie370
Try a Reset Settings in the Q box hidden menu. See if this improves the issues.
