Discussion topic: When I turn turn the tele on the screen picture does not come up
Message posted on 18 Oct 2023 10:06 AM
Hi there, when I turn my tele on. The screen picture goes funny. It's very big or is cut in half. I have to keep rebooting to get the screen to the correct size and working. I do this every time I have to watch tv. I think the sky box is going. Normal television works ok. It's when it's plugged into the sky bow. Please help
Message posted on 18 Oct 2023 10:16 AM
Re: When I turn turn the tele on the screen picture does not come up
Hi @Waterid88
