This discussion topic has been answered Discussion topic: When I turn the volume up or down on my sky Q remote I get a voice stating what the volume now is
Message posted on 08 Feb 2024 03:24 PM
When i change the volume on my Q remote I get a loud female voice stating the new level from the TV. How do I get rid of this? On accessibility it is already set to off.
Message posted on 08 Feb 2024 03:40 PM
Hi @Phippsy
You need to into the Settings of the TV set using the TV set remote.
It is purely a TV set message and nothing to do with the Q box settings.
Hi @Phippsy
Message posted on 08 Feb 2024 06:11 PM
Re: When I turn the volume up or down on my sky Q remote I get a voice stating what the volume now i
Thanks. I haven't used the TV remote since I've had it as I ve always used the sky one so it will be a lot of searching for the right button. I'll try that. 🥺
Message posted on 08 Feb 2024 06:23 PM - last edited: 08 Feb 2024 06:28 PM
Hi @Phippsy
If you have any further difficulty with the TV Settings just post back with the model and brand of your TV.
Once you use the TV remote to enter your TV settings you just need to check each menu for audio settings.
Message posted on 08 Feb 2024 07:06 PM
Message posted on 08 Feb 2024 07:46 PM
Hi Old fella,
It's a Sony
Model no KD49XG8096
Cant find the action on the menus anywhere in order to cancel
Message posted on 08 Feb 2024 08:17 PM - last edited: 08 Feb 2024 08:20 PM
@Phippsy wrote:
Hi Old fella,
It's a Sony
Model no KD49XG8096
Hi @Phippsy
Dont know if the following will help.
Accessibility] has a shortcut function so you can turn it on or off by pressing and holding the MUTING or MUTE button on the remote for 3 seconds.
If the Q remote is paired to the TV for volume you should be able to switch Accessibility On or Off by holding its Mute button for 3 seconds
Message posted on 08 Feb 2024 08:49 PM
Oldfella,
You are a bloody star. That worked a treat! It's been doing my head in. All fixed.
Thank-you so much buddy.
Nick 😀👍
Message posted on 22 Jul 2024 06:43 AM
I had the same problem with my sony bravia tv. It just started with a loud voice coming through the tv speaker everything I altered the volume. It also kept repeated the word "timer" without any action on my part. Eventually I read the advice about accessing "accessability" in SkyQ but pressed the mute button on Sony controller and it has worked. Annoying loud voice now removed!!!
Message posted on 26 Dec 2024 12:26 AM
I had this problem, if you press and hold the mute button on your sky remote for 3 seconds, it's worked for me.
Message posted on 17 Nov 2025 11:16 PM
Had same trouble as Phippsy. Couldn't find in settings on tv.Pressing mute button for 3 seconds worked a treat. Thanks for that - you are a star!!!
