Discussion topic: When I try to watch a recording on my Sky Q box, it won’t work & keeps saying technical fault
This message was authored by: MP7
My recordings won't play saying technical fault and then when I try and watch live TV, after pressing play for a recording the screen freezes. I'm having to watch TV on my mobile
Re: When I try to watch a recording on my Sky Q box, it won’t work & keeps saying technical faul
@MP7 The first thing to try is  rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Hi @MP7
