Discussion topic: When I check for a Network for my Firestick, it shows a very strong Sky option
Message posted on 14 Nov 2023 03:42 PM
However, I do not have Sky broadband, so is that Sky Network option the actual SkyQ box and can I use it to connect to the Firestick? I do not have a password for it.
Message posted on 14 Nov 2023 03:54 PM
Re: When I check for a Network for my Firestick, it shows a very strong Sky option
https://www.sky.com/help/articles/wifi-hotspots
Message posted on 14 Nov 2023 05:19 PM
Hey @TimmyBGood ,
Thanks for getting back to me. I have done that and turned on the hotspot but it still requires a password ?
Kieran
Message posted on 14 Nov 2023 05:52 PM
@kohireland wrote:
Hey @TimmyBGood ,
Kieran
Hi @kohireland
Hotspot performance is not guaranteed.
The password will be your normal Network.
Message posted on 14 Nov 2023 05:57 PM - last edited: 14 Nov 2023 05:57 PM
hi @kohireland
in case of any confusion - you can't connect directly to the SKY wifi you see - the hotspot is still your home wifi
Message posted on 14 Nov 2023 07:46 PM
Thanks Oldfella and Nigea99, I get you! I tried to connection, using the password for my router and it came up with a connection error and the Sky Network is now not available (i.e. the connection symbol is crossed out). I am confused. I do have Hot Spot truned on btw.
