7
This discussion topic has been answered Discussion topic: What satellite cables do I need to connect to sky q box
This message was authored by: Pasty
Hello, I had to return my sky q box and had a replacement delivered, I stupidly put in the satellite cables, what cables should I buy I am confused, is it male to female, male to male, I rang sky and they cut me off.  Any help would be appreciated.
This message was authored by: nigea99 Answer
Re: What satellite cables do I need to connect to sky q box
Hi @Pasty
I am guessing you have a Communal feed with a connection on the wall, rather than your own dish
The connectors on the leads are Male to Male using 'F plug connectors'  - You usually find  them online as 'Satellite extension leads but note some are correct with M-M connectors and a F-F adapter - some may be Male-Female so do check.
F ConnectorsF Connectors.
hi @Pasty
Normally the satellite cable come direct through the wall to the satellite dish.
If you have wall faceplates then you will need 2 short cables to connect to the Q box.
Satellite cable extensions are readily available online.
 these come with a joiner if required at the wall plate.
Hi @Pasty
This message was authored by: Godfrey
@Pasty   If you are using a communal satellite transponder signal feed from a wall mounted media plate then it will require your new replacement Sky Q receiver being re-configured to use 'SCR' LNB mode, instead of the default 'Wideband' LNB mode that it will have been initially configured to use.
Godfrey.
Avatar for Pasty
Hi, thank you so much, I have ordered the cables, disappointed with SKY as they cut me off, she obviously couldn't be bothered to help, my fault, I literally did what they said and sent everything back. But thanks for taking the time to help me.  Kind regards.  Pasty
Avatar for Pasty
Hello thanks for the photo and info, I have ordered a new set thank you for taking the time to send me a photo, much appreciated
This message was authored by: Shay44
I have one into the router & one in the tv , both obviously plugged on
Sorry, what? Is this related to the poster above and their thread?
