5
This discussion topic has been answered Discussion topic: What is the cheapest way to get sky TV in a holiday home, I have Sky’s multi room at home
This message was authored by: Mikeham1
I want sky tv ultimate at a holiday home with good WiFi.
I have Sky' q at home with multi room.
can I piggy back from my home sky to a good deal for the holiday home as I can only be in one place at once?
can I get sky stream at the holiday home
This message was authored by: nigea99 Answer
Re: What is the cheapest way to get sky TV in a holiday home, I have Sky’s multi room at home
using SKY Go is probably the cheapest but to see on a big screen you probably need to use a PC/Laptop with an HDMI out
Otherwise you would need a separate subscription  but this is unlikely to be discounted beacuse you have a SKY at your main home.  As it would be a separate subscription you can have either Q or Stream.
Edit : rather than a second subscription to SKY Q or Stream a  Now TV subscription just for whilst you are there may be more suitable
Avatar for Mikeham1
OK great point. so if i buy a Tv with mirroring from teh iphone. Can I use Sky go and mirror onto a 65inch TV??
@Mikeham1
Unfortunately not,  SKY Go does not allow mirroring
(BTW please also see my edited earlier post re Now TV - although I am not au fait with which devices can be used - I think it is more likely to be able to used on a TV)
Your best bet is using an Apple TV 4K box with the Sky Go app. But be warned, Sky Go is limited to outputting 720P so it's never going to look great on a 65" screen.
If you want UHD and HDR then you'd be better off getting a NOW TV subscription with Ultra Boost on an appropriate streaming device.
This message was authored by: 2muchTV
Assuming you have decent broadband at your holiday home, Now TV maybe your answer.
I regularly work away from home (UK & Europe)  and I take a 4K Firestick and remote which has the Now TV app et al.
[Removed]
Moderator notes: Removed info on how to circumvent geo locking.
Former Sky HD+, Q and Stream customer
Now TV Sports + Entertainment + Cinema + Ultra Boost @ £34 pm (till April 2026)
1000/115 FTTP (Aquiss) to Zyxel DX3301
3 x Asus XT9s + + RT-AC58U V3 for WiFi (AP mode)
65" Samsung S92C OLED TV
C430 Samsung soundbar with subwoofer
6 other streaming TVs
43+ network connected devices
