Discussion topic: What hdmi cable is recommended to connect sky uhd to a lg qned 4k 120hz tv
Message posted on 14 Jan 2024 03:40 PM
What hdmi cable is recommended to use with a sky q box with uhd connected o a lg qned 4k 120hz tv
Message posted on 14 Jan 2024 03:53 PM
Re: What hdmi cable is recommended to connect sky uhd to a lg qned 4k 120hz tv
@Andym1963 the one that Sky supplied should be pefectly fine
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 14 Jan 2024 03:57 PM
Thanks for the reply looking for a cable about 5m
Message posted on 14 Jan 2024 04:24 PM - last edited: 14 Jan 2024 04:25 PM
Hi @Andym1963 5m high speed Amazon basic cable should be okay for HD. Any passive cable over 3m long is pushing it for UHD. You will be in fibre optic territory.
Message posted on 14 Jan 2024 04:48 PM
Anything certified for 18Gb is fine.
Sky is 50Hz. 60 on some apps with US content. So you don't need a 4k x 10bit x 120Hz capable cable.
