Discussion topic: What has happened to UHD!?! HLG is CRUD
Avatar for Colonicus
This message was authored by: Colonicus
Re: What has happened to UHD!?! HLG is CRUD
I've changed nothing! One minute I get UHD next minute I don't! I get sludge!
I am a 'if it works don't fix it' person... switch on... choose channel... watch!
it's on 10 bit... won't change to 8
I give up... maybe it's the box or dish but I'm not doing anything any different today than i was doing a week ago when I had a great picture!
Thaks tho!
This message was authored by: Godfrey
@Colonicus  To change from 10-Bit to 8-Bit
Press the HOME button on your remote control
Press the DOWN arrow button 12 times to highlight SETTINGS
Press SELECT
Press the DOWN arrow button 4 times to highlight SETUP
Press SELECT
Press the DOWN arrow button 3 times to highlight AUDIO VISUAL
Press the RIGHT arrow button twice to highlight 2160p UHD
Press SELECT
Press the RIGHT arrow Once
Press the DOWN arrow button twice to highlight 8-bit
Press SELECT
Godfrey.
NB. If you answered TimmyBGoods's question with respect to the model number of your TCL TV, it would certainly help us to provide much more accurate advice tailored to the ability of your specific TV to display HDR images
@Colonicus wrote:
Are the others like Virgin also using this HLG?
Yes.
@Colonicus wrote:
i signed up for TV not rocket science!
Satellite television is quite literally science with added rockets.....
That failed but put it on Find it For Me and seems better.  I'll give it a proper try out shortly !
Thanks... fingers X
That failed but put it on Find it For Me and seems better. Still about 8 second black screen before it went onto 401 and same back to a normal channel ... still not quite right. Brighter but not right!
very bright on normal HD...
