Discussion topic: What Happens to Sky Cinema if I Cancel Sky TV?
Message posted on 19 Jun 2025 02:01 PM
Message posted on 19 Jun 2025 02:18 PM
Re: What Happens to Sky Cinema if I Cancel Sky TV?
@Tusia91 Pretty sure that when you added Sky Cinema your TV contract would have been reset to run for 24 months too.
If you look in the My Sky app you'll be able to see if this is the case.
As far as I know you need to have a Sky TV subscription in place, you can't just have Cinema or Sports.
Message posted on 19 Jun 2025 02:23 PM
@Tusia91 as @Anonymous indicates adding additional subscriptions does indeed extend the base subscription as you can't have anything else without it
Message posted on 19 Jun 2025 02:27 PM - last edited: 19 Jun 2025 02:27 PM
If the Cinema deal offer date goes past the base TV pack then you will continue with the base pack at full list price* as you cannot cancel it. (The premium channel requires a base TV pack)
* unless you agree a new deal that co-terminates
Message posted on 19 Jun 2025 04:32 PM
Thanks, that actually clears things up a lot.
I spoke to Sky and asked several times if I could still cancel all my TV services in October, and I was told yes. But later in the app, I noticed Sky Cinema showed as running until 2027, which confused me.
- Your explanation makes sense now – it looks like when Sky Cinema was added, it may have extended or reset the contract to 24 months. I've already cancelled the Cinema add-on now to avoid being tied in longer, and I’ll be cancelling Sky TV entirely when my main contract ends in October.
Appreciate the help 👍
Message posted on 19 Jun 2025 04:38 PM
This doesn't make sense. You said you added Cinema until 2027 - if you did as a minimum term then you can't cancel.
And if the base TV contract was extended then you can't cancel that!
Check the minimum term dates on your account - each service will display, "In contract to dd/mm/yyyy".
Message posted on 19 Jun 2025 04:40 PM
@PandJ2020 Doesn't 'cooling off' period apply on TV packages?
Message posted on 19 Jun 2025 04:48 PM - last edited: 19 Jun 2025 04:49 PM
Not usually
Also, usually any TV packages that are 'Trials' (free or reduced cost) rely on the customer to cancel, otherwise they renew automatically
Message posted on 19 Jun 2025 04:52 PM
@Anonymous wrote:@PandJ2020 Doesn't 'cooling off' period apply on TV packages?
I didn't think it did with Cinema and Sports. Otherwise you could deliberately subscribe for less than 14 days as needed.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 19 Jun 2025 04:55 PM - last edited: 19 Jun 2025 04:58 PM
@Anonymous not on renewals only on initial sign ups
the reason why is because on renewal you are agreeing to continue a service that you are already receiving whereas on sign up you don't start paying until you start receiving the service which can be awhile after ordering because of delivery of equipment and setup if an engineer is required
in this case with cinema the activation is instant as the equipment and main service is up and running so that renders the cooling off period irrelevant
Message posted on 19 Jun 2025 05:04 PM
@SKY1992bf I'm seeing information online, including from posts in 2024, where customers have agreed to a new contract, then changed their mind within 31 days and have been able to cancel.
As the original poster had been given a new 24 month contract after adding Cinema then they did have the right to cancel and revert back to their old contract. If they had been outside the 31 days/14 days in ROI, then they would have been stuck.
Would be useful if someone from Sky could give us the right information though?
Message posted on 19 Jun 2025 05:07 PM
@Anonymous wrote:@SKY1992bf I'm seeing information online, including from posts in 2024, where customers have agreed to a new contract, then changed their mind within 31 days and have been able to cancel.
In that case best for @Tusia91 to speak to sky directly
Message posted on 19 Jun 2025 05:09 PM
@SKY1992bf The OP has already spoken to Sky and has cancelled Cinema and gone back to her old contract, which expires in a few months time.
Message posted on 19 Jun 2025 05:15 PM - last edited: 19 Jun 2025 05:17 PM
@Anonymous wrote:@SKY1992bf The OP has already spoken to Sky and has cancelled Cinema and gone back to her old contract, which expires in a few months time.
@Anonymous I don't think there's a definitive answer here as it's solely at sky's discretion on a case by case basis as to whether the cooling off period applies in the same way cancelling without early termination charges is
in this case op got the resolution they wanted
