Discussion topic: We have no reception. It says there is a technical fault with this channel, please try again later
This message was authored by: DaviesMer
Re: We have no reception. It says there is a technical fault with this channel, please try again lat
@DaviesMer Have you tried rebooting your main Q box ie
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
@DaviesMer
Have a look at this link
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
(Your duplicate post was removed).
