Discussion topic: We have many channels that are not currently working
This message was authored by: Suzie3110
Many channels are not working on our sky
Avatar for Suzie3110
Level 0 icon
Re: We have many channels that are not currently working
 this is showing on a number of channels. We have tried to reset it and it is still not working
@Suzie3110
If you are currently experiencing heavy rain or high winds it will affect your satellite signal. Otherwise if a “no satellite signal” message continues to be displayed firstly check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Also check out the troubleshooting on this link
It may then give you the opportunity to arrange an engineer to check the alignment of your dish (it’s not something that will necessarily be visible to the naked eye). If you’re on a communal dish you may initially need to liaise with your landlord or building management company.
