Discussion topic: We have looked the aerial wire is corroded from the outside in.
Message posted on 21 Mar 2023 06:03 PM
Aerial wire corroded from the outside in. No signal sign showing on all channels.
Message posted on 21 Mar 2023 06:06 PM
Re: We have looked the aerial wire is corroded from the outside in.
Do you mean cables from the satellite dish as Sky Q doesn't connect to your TV aerial? Is your screen showing no signal or no satellite signal?
Message posted on 21 Mar 2023 06:11 PM
No satellite signal
Message posted on 21 Mar 2023 06:13 PM - last edited: 21 Mar 2023 06:29 PM
If you mean the cable from the dish, then the dish, cables and LNB are your property but Sky will usually repair or replace it if there are problems.
