This discussion topic has been answered Discussion topic: We have issues with our sky minibox
Message posted on 10 Nov 2023 06:03 PM
We recently terminated our broadband contract with sky and kept getting a message from sky asking for us to return the minibox too. We are still paying for this service but our minibox is not work. Apps are working and the main sky box is working too. Any advice please!?!
Message posted on 10 Nov 2023 06:19 PM - last edited: 10 Nov 2023 06:20 PM
@Julesmotty wrote:
We are still paying a subscription for mulitroom
hope it is Multiscreen (not Multiroom)
And what about the Setting in Status @Julesmotty ?
Message posted on 10 Nov 2023 06:15 PM - last edited: 10 Nov 2023 06:15 PM
Re: We have issues with our sky minibox
Hi @Julesmotty
You need to check that the Q Monthly Multiscreen is still part of your subscription.
You can check your package in the Q box under (My Sky at the bottom of the Home menu).
Also check on your Q box in Home - Settings - Status and see if you have a tick or a cross next to Watch on Sky Q mini box.
Message posted on 10 Nov 2023 06:17 PM
Message posted on 10 Nov 2023 06:21 PM
It was all fine and said we are set up to watch tv our minibox.
now it saying connecting to your sky q (minibox) and has the circle come up which has been the case for the past few mins.
Message posted on 10 Nov 2023 06:24 PM
Hi @Julesmotty
Reboot the mini as above.
It is multi screen subscription.
Message posted on 10 Nov 2023 06:30 PM
Then try the suggestions in my previous post @Julesmotty
