25 Aug 2024 11:25 AM
Hi
we've had sky q since last September the main box downstairs and a mini box upstairs plus a booster downstairs. Everything has been okay until I had sky broadband installed and although I have no problem downstairs, the booster is no longer connected and I am unable to install anything on the mini box.
Can anyone help please?
25 Aug 2024 11:37 AM
@caryl+jewitt wrote:
Hi
On Sky Broadband you can use the WiFi booster to connect to your router or your main Q box. That's provided it is a Sky Q WiFi booster.
If you main Q box is successfully connected to your Sky router then you can use the Q booster located between your main Q box and the mini.
Assuming the main Q box is connected correctly you need to set up the Q booster as follows.
Position the booster approx midway between the main Q box and the mini.
Tip: Need to move your booster after you've connected, don't worry it will automatically reconnect when its moved as long as its within range of your main Q box.
Then carry out a Network Reset on the mini.
Highlight Status and then select Reset on the right hand side. Follow instructions to WPS with Q device,
You will be asked to press the WPS button on the Q booster box (not the mini as the Network reset will start the mini WPS automatically).
25 Aug 2024 11:58 AM
I've been trying to connect the mini box but it permanently shows a red light and the tv says no video signal!
Thank you for trying to help me, I'm just not very technically minded.
25 Aug 2024 12:03 PM - last edited: 25 Aug 2024 12:04 PM
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the Q box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
25 Aug 2024 12:07 PM
Have you received a black or a white Hub from Sky?
27 Aug 2024 09:28 AM
Sorry for not thanking you for your help but my head is not in the right place at the moment, I am having a lot of family problems at the moment so haven't attempted to deal with my booster and mini box but thank you once again.
