Discussion topic: We had to unplug everything to move the tv and sky w box. Now it’s not working?
This message was authored by: SH2
This message was authored by: Invisiblename
Re: We had to unplug everything to move the tv and sky w box. Now it’s not working?
If it's "all unplugged" it's not going to work 😋
Are you sure you've reconnected it all correctly?  You can check here:
https://www.sky.com/help/articles/setting-up-sky-q-setting-up-new-box
I am just another Sky customer!
This message was authored by: twilight+princess
Does the TV &/or Sky Q box turn on?
Is the TV on the correct input?
Obvious but check to see if the power socket is turned on for both TV & box.
Virginia.
I don’t work for Sky.
If I have helped then please leave a like.
