Discussion topic: We had a power cut. Now both mini booster boxes will not connect.
Message posted on 24 Oct 2023 09:01 PM
I have rebooted and powered off and on both boxes. The connection light is off on both. I have restarted the Wi-Fi as well.
Message posted on 24 Oct 2023 09:06 PM
Re: We had a power cut. Now both mini booster boxes will not connect.
Did you reboot the Main Q box before rebooting the minis?
ie
First try rebooting the main Q box and then when this is completely back up and running reboot the minis (starting with the one nearest to the main Q box.
Reboot the mini as above.
If the mini still does not connect try a Network Reset on the minis (starting with the one nearest to the main Q box.
When you carry out the Network reset on the second mini you can use the WPS on the first connected mini if nearer than the main Box.
Message posted on 24 Oct 2023 09:24 PM
Hi
Thank you for your help. Unfortunately it didn't work. Do you have a phone number to contact Sky direct?
Many thanks
Message posted on 24 Oct 2023 09:26 PM
Hi
Many thanks
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Message posted on 09 Dec 2024 03:32 PM
Thanks, I followed your instructions to a tee and I now have 2 mini boxes working. No need for an engineer which I had to wait 2 weeks for. Good advice, you should work for Sky.
