Discussion topic: We gave a new router ut the sky mini box in the bedroom will not work bedroom
Message posted on 21 Aug 2024 11:41 AM
We have a new router but tge sky mini nox in tge bedroom will not connet
Message posted on 21 Aug 2024 11:51 AM
Re: We gave a new router ut the sky mini box in the bedroom will not work bedroom
Hi @Crosa56
Reboot the mini as above.
