This discussion topic has been answered Discussion topic: “We can’t connect to your broadband router”
Message posted on 27 Sep 2023 09:52 AM
BT broadband working perfectly but SkyQ box says "can't connect" and going through the Netork Connection>Reset process, it won't accept the "Confirm" instruction to the "Are you sure you want to continue?". Only other option is "cancel". Have switched off and on and reset router but nothing works. Help!
Message posted on 27 Sep 2023 11:50 AM
Unplugging QBox and plugging back in fixed it!
Message posted on 27 Sep 2023 11:06 AM
Re: “We can’t connect to your broadband router”
@Martin5858 wrote:BT broadband working perfectly but SkyQ box says "can't connect" and going through the Netork Connection>Reset process, it won't accept the "Confirm" instruction to the "Are you sure you want to continue?". Only other option is "cancel". Have switched off and on and reset router but nothing works. Help!
I've had that before. Massively annoying. Random and got it to work in the end but no idea how.
Message posted on 15 Apr 2024 08:02 AM
Can't connect to broadband tried to change WiFi password
