Discussion topic: We are having an issue with our mini sky q box bot working at all '
Message posted on 13 Apr 2024 06:07 PM
We had to have an electrician on yesterday as we had a fault with our electric and the power was off for a while we have tried to set it up ourselves and now the box isn't working at all
Message posted on 13 Apr 2024 06:21 PM
							Re: We are having an issue with our  mini sky q box bot working at all '
Hi @Stephi45
Reboot the mini as above.
