Discussion topic: Water under my sky q box
Message posted on 12 Apr 2023 09:35 AM
I've just discovered water under my sky box, where did it come from, as it's not anywhere near a water supply
Message posted on 12 Apr 2023 09:50 AM
Re: Water under my sky q box
@Rowdy7 wrote:I've just discovered water under my sky box, where did it come from, as it's not anywhere near a water supply
Definitely not the Sky box... got any children in the house?
Message posted on 12 Apr 2023 10:47 AM - last edited: 12 Apr 2023 10:53 AM
It's not unheard to have water track down the satellite feed cables. Are these wet around the point where they come through the wall?
Message posted on 12 Apr 2023 11:13 AM - last edited: 12 Apr 2023 12:43 PM
As @Eeeps indicates, if it's a main Q box then you've got all that cable to the dish and a hole in the wall: there should be a curve in the cabling lower than the drilled entry point (known, for obvious reasons, as a 'drip loop'). In addition it's not unknown, in extreme cases or with elderly installations, for water to come down inside the cable sheathing and emerge at the screw-thread connector (although you might expect that to knock out the signal/LNB/box).
Obviously switch off and unplug at the mains socket before doing anything else. Note that when plugged in the box is sending a (small) current up to the LNB on the dish, so seeping water is potentially 'live'.
Message posted on 12 Apr 2023 12:23 PM
