Discussion topic: Watching Netflix on main Sky Q box, every 30 seconds (sometimes less) the screen goes black for abou
Message posted on 03 Aug 2023 07:54 PM
Watching Netflix on my main Sky Q box, between every 5 - 10 seconds the screen goes black then comes straight back on again. This may sound petty but when you are trying to watch something it becomes really annoying.
it's not happening on the mini box
Any suggestions please.
Message posted on 03 Aug 2023 07:56 PM
Re: Watching Netflix on main Sky Q box, every 30 seconds (sometimes less) the screen goes black for
Hi @Toni2
Try a Reset Settings in the main Q box hidden menu.
