Discussion topic: Wanting to use a separate Sky sim for a hot spot on my Sky Q box
Message posted on 12 Apr 2023 10:26 AM
I have been let down by a Vodafone Gigacube (mobile broadband) I have used my Sky mobile to tether to my computer as a WiFi hot spot and it works well. So I tried to get my Sky Q box to use this hot spot. I did as suggested by other users and I did manage to turn the hot spot on but then got the message for other networks. Enter the name (SSID) of your network and Security , , it shows all the WPA types and then none.
I did see the hot spot on/off and turned it to on but I do not see my iPhone which is a Sky mobile with a Sky/O2 sim
Message posted on 12 Apr 2023 11:31 AM - last edited: 12 Apr 2023 11:35 AM
Re: Wanting to use a separate Sky sim for a hot spot on my Sky Q box
I think this is an Apple issue: by default their current OS releases apply WPA3 security to a 'hotspot', but a Sky box cannot use WPA3. You'll need to find the setting on the iPhone to knock hotspot security down to WPA2.
Message posted on 12 Apr 2023 11:34 AM - last edited: 12 Apr 2023 11:36 AM
That setting may be cunningly disguised here:
