3
This discussion topic has been answered Discussion topic: Want to upgrade to sky glass offer with the tv, sky, and Netflix
This message was authored by: KLMxo
I want to upgrade my sky Q package to the sky glass package where you get the tv, sky and Netflix for £40 a month and only £14 for the first 3 months, it says it can transfer my current package over to that which is fine but I want sky in my other room so will my sky box still work ( so I can use that in the other room as sky is built into the sky tv) or will I have to get the sky puck which comes up in the package? Don't want to order one if I can still use the sky box
Re: Want to upgrade to sky glass offer with the tv, sky, and Netflix
Hi @KLMxo
It you change to Sky Glass your Q subscription will cease and all Q boxes have to be returned to Sky.
You will need the Glass pucks
Hi @KLMxo
Avatar for KLMxo
Level 0 icon
Okay that's fine, but there must be a monthly charge for the puck it says one off fee was £39.95 which is now £0 for the offer but doesn't say anything about monthly charge for that?
Yes @KLMxo
You need the monthly Glass equivalent of Multiscreen to use pucks.
Its called the Whole Home pack
Answered - Go to Answer
