Discussion topic: Want to get Netflix, at the moment sky is offeringit for £6, don’t really understand what is basic?
This message was authored by: jinksey
Want Netflix, sky offering it for £6 , will I be able to watch upstairs and children downstairs? It's basic! Also are there adverts?
is it better through sky or Netflix?
many thanks for help.
Re: Want to get Netflix, at the moment sky is offeringit for £6, don’t really understand what is bas
hi @jinksey
No rhere are no adverts - it is the old Netflix Standardwithout adverts
You do get Basic level as standard butw hen you pay for Netflix via SKY, the Netflix level just depends on other SKY add on packs :
https://www.sky.com/help/articles/netflix-faqs
Netflix Basic plan (1 screen + SD) as standard  (although I think this is now HD )
Netflix Standard (2 screens + HD) by adding the SKY HD pack
Netflix Premium (4 screens + UHD/HDR) by adding the SKY Ultra HD pack (requires the HD pack first)
These SKY add ons of course apply to SKY content as well as opening up Netflix levels
P.S. When you pay via SKY, you cannot, currently, add the 'extra member' add on for use by family members not in your physical household that is available for those paying directly to Netflix
So if you already have or wish to benefit from the SKY add ons this can work out cheaper than via Netflix direct for the higher levels in particular
@jinksey
Note that you won't find reference to Basic on the Netflix website because they no longer offer it as a direct subscription: it is however the Ultimate TV baseline product through Sky.  As  @nigea99 indicates, it's no advertising, lower resolution and only one screen in use at a time.
