Discussion topic: Volume buttons and voice button on my remote don’t work
This message was authored by: Emma1976
Some buttons on 1 remote don't work. Changed batteries, made no difference
Re: Volume buttons and voice button on my remote don’t work
Hi @Emma1976
Try completly resetting your Bluetooth remote.
Failing this
Check the following link and it will lead to a form for a replacement remote.
https://www.sky.com/help/articles/lost-stolen-damaged-sky-q-equipment.
In the meantime if you have an Apple device with Sky Go you can set up a virtual remote to control your Q boxes.
See following link.
https://helpforum.sky.com/t5/Sky-TV/Virtual-Sky-Q-Remote-Now-Available-on-Sky-Go/ba-p/4363637?
Avatar for Emma1976
I tried repairing, I'll use form to get a new remote.
many thanks
