8
This discussion topic is read only This discussion topic has been answered Discussion topic: Voice guidance
This message was authored by: Max641
Voice guidance
Is anybody  having an issue with voice guidance option in accessibility settings on a Sky Q box? My voice guidance stopped working on Friday.  Sky tech support went through every possible fix including a factory reset but didn't solve the problem.
This message was authored by: KevNewMedia Answer
Re: Voice guidance
Posted by a Sky employee
Hi Everyone
Our support teams have advised that they believe this issue is resolved.
Is that the case for you?
I'm going to mark this post as the current answer, so that everyone has the most up-to-date information.
Kev
Community Manager
Locked
Re: Voice guidance
Hi @Max641
Have you checked that your Q box HDMI Audio is still set to Normal?
Found in Home - Settings - Setup - Audio visual.
Voice guidance will not work with Dolby audio settings.
This message was authored by: Midsrob
Re: Voice guidance
Hi Max641
yes, same problem here. Stopped working on Friday too. I have done all resets and tests and it will not come back on. At least one other person has also mentioned that the same has happened , on the accessibility section of the forum.
looks to me like the problem is Sky's end.
Avatar for Max641
Re: Voice guidance
Yes, it's set to normal but still not working. Strange that tech support never suggested this as a possible solution🤔. Thanks for the advice👍
This message was authored by: Gardening1234
Re: Voice guidance
I've been having trouble since Friday too.  Was told it's a problem with them and they are working on it.
Re: Voice guidance
It is at sky end, that's what they told me.  Said they was working on it.  I don't think they must be. Not good enough!
Re: Voice guidance
Hi Everyone
Thank you for coming to the Community to tell us about this problem.
We apologise for the inconvenience this may be causing and want to make you aware that our engineers continue to work on the problem with priority.
Kev
Community Manager
Re: Voice guidance
Hi Everyone
Kev
Community Manager
Re: Voice guidance
Mine is now working again. Many thanks
Locked
